You have various options for modelling the cables. The best two options are cables or tendons. We have a suitable example for both elements in the TEDDY.
TEDDY > File > Examples > ASE > english > bridge > extern_prestress_cable.dat
TEDDY > File > Examples > ASE > english > bridge > extern_prestress_tendon.dat
In order to consider a moving cable - struts connection, you should work with cable elements. Please have a look at the two examples:
TEDDY > File > Examples > ASE > english > kinematic > slip_cable.dat
TEDDY > File > Examples > ASE > english > kinematic > slip_cable_mue.dat
The second example takes the friction between the cable and the struts into account.
Please keep in mind that the friction can only be applied in a non-linear analysis. If you define SLIP MUE 0 (no friction), you can work with a linear analysis.
Thank you very much.
Is it possible to give me a simple example with clear steps that explains this to me?
I am a new user of the program.
Thank you very much for your help.
I showed you four examples. Please have a look at them. If they are too complex, you should start with an easier example. All of our TEDDY examples are listed within the TEDDY.
If you are completely new to SOFiSTiK you should start with a SSD project. A good beginner Tutorial is our bridge design online training on YouTube.
thank you.
the teddy file you recommended
TEDDY > File > Examples > ASE > english > kinematic > slip_cable_mue.dat.
i don’t find this teddy file
can you send this file
good morning.
Can you help me on this point?
i have opened the teddy file you recommended
but i don’t know how i can benefit from this model to model this connection , i want to extract from this model how the cables modeled with friction and slip to apply this idea to the ( cable - strut connection ).
i can model the strut as fame element and the cable as cable element , but my problem how i can model the element between the cables and strut to consider the friction and slip of cables to be able to calculate the prestressing losses correctly.
thank you.
