I’m not sure what you’re extruding, but I don’t think that the green and blue elements are connected properly (DIV?)…maybe you could provide the files to see what is causing this behavior.
In the first step meshing of all SARs is done in SofiMshC. In a second step one SAR is extruded to BRICs. But in the second step the mesh of SAR 1001 is already fixed and SofiMshA is not able to change this.
Maybe you can mesh the QUAD elementes in SofiMshA, atleast for those areas which overlap the BRICs.
Alternatively, I would think about the modelling: What is the task of the thin steel plate within the thick concrete wall? Is my model appropriate for the expected loads? Do I need BRICs or can I do it with QUADs only?
