Hi
I am investigating the forces in a plate from moveable loads using the program ELLA. The loads consist of a simple vehicle with two axles which can move only in direction of the lanes i have defined. The distance between the axles is fixed to 6 meters, but the distance between each vehicle is approximately minimum 0.2m. Each of the lanes can be up to 100 meters long.
Since the load is user defined, i have defined two axles in each load case.
When using ELLA to calculate the worst section forces, ELLA does not see the two axles as being one vehicle, and therefore removes the axles which are not maximizing the section forces. I want the program to either keep or remove the whole vehicle, and not only parts of it.
Therefore i have two questions:
- Is there a way to define a specific vehicle instead of only axles?
- Or is there a way to code in ELLA that both axles should be removed if unfavorable?
The code defined in sofiload is the following:
!Containers
sto#contW 2.44[m] !Width, container
sto#contL 6.060[m] !Length, container
sto#clW 0.162[m] !container point load, width
sto#cll 0.178[m] !container point load, length
sto#contCCw 4.2[m] !C-C distance containers on row(width)
sto#contd 0.4[m] !Outer distance between containers on row(length)
$sto#Tcc 0.1[m] !Tolerance in C-C distance of containers, if 0.1m input, then total movement is ±0.1m=0.2m
sto#Pcont 182.9[kN] !Point load in each corner of container
$sto#Pstraddle 110[kN] !Point load in each corner of container
$!Straddle carriers
$sto#slw 0.232[m] !Straddle carrier point load, width
$sto#sll 0.371[m] !Straddle carrier point load, length
$sto#dstrady1P 2.1[m] !Distance straddle carrier wheels resultant, longitudinal
$sto#dstrady2P 3.5[m] !Distance straddle carrier wheels resultant, longitudinal
$sto#dstradxP 4.45[m] !Distance straddle carrier wheels resultant, width
ECHO ACT
ACT L
ECHO LANE,LOAD
GAX ‘A’ S 4*#deltxy X #Cx-3*#contCCw Y #Cy-2*#deltxy Z 0 NX 0 NY 1 NZ 0 ! Axis A creation
LANE ‘A’ TYPE EN WR #contW/2 WL -#contW/2 ! Lane in axis A defined
GAX ‘B’ S 4*#deltxy X #Cx+3*#contCCw Y #Cy-2*#deltxy Z 0 NX 0 NY 1 NZ 0 ! Axis A creation
LANE ‘B’ TYPE EN WR #contW/2 WL -#contW/2 ! Lane in axis A defined
LC 91 TYPE L TITL ‘Container Lane 1’; TRAI USER PFAC 1 XCON #contd+#cll DIR B DIRT N WIDT #contW ! Custom container load
TRPL 2*#Pcont B #contW-#clW BW #clW LW #cll
TRPL 2*#Pcont A #contL-#cll B #contW-#clW BW #clW LW #cll
LC 92 TYPE L TITL ‘Container Lane 2’; TRAI USER PFAC 1 XCON #contd+#cll DIR B DIRT B WIDT #contW ! Custom container load
