Hello Nuku,
If you want to use Teddy Input Language (CADINP) we provide several examples to all kind of topics, also dynamics.
For eigenfrequency you can have a look at the example ase4_eigenfrequencies.dat at Teddy - Data - Examples - ASE - english - ase4…
For earthquake analysis you can have a look at ASE - English - dynamics - earthquake_jb.dat
If you want to use modul DYNA, you can have a look at DYNA - english - storeys - storeys.dat using response spectrum analysis.
If you are not sure, which modul is the way to go, please have a look at our manuals regarding ase and dyna, you can find them at Teddy/SSD - Help - Manuals - All Manuals e.g. ASE p. 2-85 Chap. 2.15
Using ASE you get a quick eigenvalue analysis (Command EIGE), you can have a look at the results and eigenvalues at the report browser.
Thank you NAL for extended explanations,
there were very useful information.
But, I couldnt find any way to output stiffness matrix or mass matrix (SM or MM) of the system of structure at those manuals and examples. For example, Sap2000 has features to output SM or MM converted to text files. I cant believe that there are no ways to display these values in Sofistik.
There should be a possibility within CADINP. I remember reading some values in the CDBASE(Database). You can read through the CDBASE Help. Maybe you’ll find something there. (Help-Ribbon -> CDBASE-Help)
With @KEY you can get access to the data in your code to read them in.
Sorry,
I couldnt extract stiffness matrix of entire system of structure with @key S_MATRIX. An error window appears.
Most likely this is due to the fact that I did not correctly specify the command.
Below are the commands I used (after linear and dynamic calculations of system):
+prog template head Smatrix @cdb example1 @KEY S_MATRIX @(1,101) end
Thank you,
I get stiffness matrix only for 1 element, but not for entire system (global stiffness matrix).
I think there is no possibility for output entire system stiffness matrix
If I’m not mistaken you can’t get the stiffness matrix for an arbitrary element through the cdb.
If there is an element under record 175/00 it has been generated manually. I.e. with ADDM or FLEX in SOFIMSHA.
→ The entire matrix has ben input by the user, so the contents should already be known.
