Introduce damping in springs between structural lines
Hello
Springs between the nodes of two structural lines can be created in an attached SOFiMSHA run with a short code snipped.
+prog sofimsha
head
syst rest
spri mesh 1 2 nare 3 nere 4 CP 2000 ct 2000 dp 100
end
This code creates springs between the node sequences (node 1 and node 2) and the sequence of nodes 3 to 4. The node sequence is created from a structural line in SOFiMSHC.
Keep in mind that a damping element is only effective within a dynamic analysis (SOFiMSHA manual chapter 3.20.3 Damper).
Best regards
Frederik Höller
Your SOFiSTiK Support Team
