Imposed moving loads
I have recently started using SOFiSTiK for a project and am posting my first question regarding an issue I am facing. I would greatly appreciate it if someone could help me resolve it.
I have created a free horizontal load in the model and would like to automate the “imposed moving loads” command in SOFiSTiK. Specifically, I want to generate a moving load along my predefined axis and offset it by a certain value.
I followed a code example explained in a tutorial, but the eccentricity (dy) I applied is not being generated correctly.
+prog SofiLOAD
head ‘Définition des charges horizontales’
echo full no
echo load yes
let#start 0.80
loop#i 29
lc no 1111+#i type ‘none’ titl ‘LM1_G_Freinage #(#i+1)’
copy no 1110 ref AXE_ dx (#i*(118.35/(29.5875)))+#start dy -3.325
endloop
When I check the output, the load is being offset of a value dy = -2.51 instead of -3.325
I have the feeling that the code doesn’t take the right axis as reference and I don’t know why.
Does someone have a solution ?
One cannot help efficiently without the data set.
did you get an answer ?
Could you please share your file so we can verify your issue?
Codaster2.sofistik (37.2 KB)
I dont understund why my code doesnt work. If you can find the issue, and explain to me i will be glad. Thanks
Amine, can you explain the objective of your model and what exactly is not working?
I’m working on a dynamic analysis project. I would like to model a beam with a periodic load and analyse the results. I wanna make a time step analysis and compare the moments and displacement per time. I tried a code but I don’t understand why it doesn’t work.
