I am running a transient thermal analysis on the construction phases of a dam.
At the report file at the first analysis under general parameters it has : Nonlinar ON.
At the next analyses under general parameters it has : Nonlinar OFF.
I am using the default interation method (KITE 1) and the analysis is running sucessfully
but why does it says that Nonlinar is OFF?
Thank you in advance
without any further information I don’t know why the program changes the calculation from non-linear to linear. Have you seen our TEDDY examples? Perhaps they help you understand the program behaviour.
TEDDY > File > Examples > hydra > english > …
Thank you for your answer.
Unfortunatelly I could not find a solution from the Teddy examples.
My teddy file is as follows: (after i have made the geometry and materials)
I want the LC 1 to be for the grp1 with a specified time function 1
then the LC 2 to be for the grp 1 and 2, where the grp 2 has the function 2
which continiues from the time LC 1 has ended
at the results it has nonlinear for LC 2 OFF but nonlinear ON for the LC 1
What error I am making? thank you in advance
Stavros Markantonis
+PROG HYDRA urs:3
HEAD ‘Transient Analysis’
SYST DIMT H DIMQ W ;
ECHO VELO NO
ECHO STEP 2
PLC NO 1 HP 18.0
LC 1 TITL ‘CONSTRUCTION STAGE 1’
STEP 20 12 ;
GRP 1
SURF TYPE QIS VAL 29.282 NB 0 F 1 FROM 10001 TO 19999 INC 1
BOUN TYPE SPEC VAL 6.5 NB 0 F 0 FROM EDGE TO 201 VP 18.0 EPS 0.0
#INCLUDE BLOCK_FUNC
HEAD 'CONSTRUCTION STAGE 2
ECHO VELO NO
ECHO STEP 2
PLC NO 1 T CONT
LC 2 TITL 'CONSTRUCTION STAGE 2
STEP 20 12 ;
GRP 1
GRP 2
SURF TYPE QIS VAL 29.282 NB 0 F 1 FROM 20001 TO 29999 INC 1
BOUN TYPE SPEC VAL 6.5 NB 0 F 0 FROM EDGE TO 202 VP 18.0 EPS 0.0
