How to get envelope of internal force under traffic load?
The structure is a 3-span continious beam.
The dat is attached:
3-span.dat (2.0 KB)
I define a unit vertical load on it,
LC NO TYPE
100 L
TRAI TYPE
USER
TRPL P
I want to get envelope diagram of 3 internal forces under this unit traffic load
CALC TYPE LMAX LMIN
MY 10 11
VZ 20 21
MT 30 31
How to envelope diagram of 3 internal forces?
You already have it.
Open wingraf and check the results for beam elements and the loadcases 10,11,20,21
MT doesn’t exist since none of your loads generate a twist.
Thank you for the tip. I can find the diagrams in the wingraf.
I also want to see the envelope in the report broswer, below is the code:
PROG WING
LC NO
10
BEAM TYPE
MY
LC NO
11
BEAM TYPE
MY
But it shows warning:
+++++ warning no. 806 in program gr3_e_stab
BEAM TYPE MY loadcase 10 not valid : No values found
BEAM TYPE MY loadcase 11 not valid : No values found
Complete dat: 3-span.dat (1.6 KB)
For teddy user, you:
  • Generate the graphics/pictures in wingraf
  • Save the file
  • Open the file with teddy
  • Paste the code into teddy (a prog wing section)
For ssd:
  • Insert a wingraf task
  • Generate the graphics pictures
  • Calculate task
