Hi I am trying to extract results into Excel through vba of MOR and Reliability under ULS as well as Under SLS stress in concrete and steel for applied moment.Please help me how to do it.For the first time I want to do my design sheet automated by changing section size and after running calculation via macro it should automated reflect required results from AQB
I recommend to use existing features within Resultviewer, see video #14 under
in chapters
03 Create a result set table
and
04 Export to Excel from a table
This should help.
Thank you for your reply.
The #14 Video shows the how export the results into the excel but i am looking in away to extract results of sofistik directly through excel Macro that will helps to extract results instantly. Could you let me know to develop a vba code to extract sofistik results
