Hello Everyone,
I have a set of wind loads that are acting on the roof and walls, presented in a tabular format (generated from another software). Currently, I am seeking guidance on how to apply these loads to the respective areas of the building. To illustrate, I will elaborate on the roof condition, as you can observe below, the roof is divided into four distinct sections, each with its corresponding length and load value.
Traditionally, structural engineers would utilize software like SofiPlus to draw rectangles or lines representing these load areas on the building’s design. Then, they assign the appropriate wind loads to these designated areas. Like below.
They are expecting me to automate this method with the help of teddy. I have one methodology in mind that:
- Extract table form the source with python (finished)
- Using the values write a valid teddy code with string interpolation and produce
output.dat
(Need your help) - In
Sofi/Teddy
:#include the 'output.dat'
(Yes, I can)
I need your help to acheive step 2. I tried to understand (read help doc, analysing the example sofiload.dat\english\wind_on_building.dat
) how to apply wind load as a AREA
load, but unable to understand it. Unfortunately it is very advance topic to my knowledge. How to enter lengths to create area for the loads? How the system will differentiate between roof areas and wall areas?
