The nodes are created during mesh generation.
I want to add supports on the nodes with its x corrdinates=0, y corrdinates are between -1 to 1.
How to achieve this?
+prog sofimsha urs:60
head
syst rest
ctrl rest 2
mod node xmin -0.001 xmax 0.001 ymin -1 ymax 1 zmin -999 zmax 999 fix pz
Thank you,
I want to put “PP” on the nodes with x=-0.5, z=-0.5, and want to put “PYPZ” on the nodes with x=3.5, z=-0.5.
Below is the code:
MOD | TYPE | XMIN | ZMIN | XMAX | ZMAX | FIX |
NODE | -0.501 | -0.501 | -0.499 | -0.499 | PP | |
NODE | 3.499 | -0.501 | 3.501 | -0.499 | PYPZ |
But I still get error:
+++++ error no. 2010 in program SM_IA_NODE ; input line: 21
Node number -1 is not allowed
All the teddy files are attached
Aqua.dat (247 Bytes)
SofimshA.dat (666 Bytes)
SofimshC.dat (4.4 KB)
SofimshC - Vol.dat (130 Bytes)
Solid Slab with Holes.dat (137 Bytes)
OK, I figure that out, the MOD command doesn’t allow table format
