Hello, I have just started with Sofistik. I want to perform an analysis of A rectangular steel beam (material S355), length 3m, which is supported on both sides by pinned support, and there is a point load of 5KN in the middle point (L/2). The cross-section has a height of .02m and a width of .20m. I have written the follow teddy code but its not working. Can you please help me with it what is the problem here.
+PROG AQUA urs:1
HEAD Definition of materials
$ Definition of the code or regulation
NORM EN 199X-200X $ Specify the European code as requested
$ Material definitions
STEE 1 S 355 TITL ‘S355 Steel’#
SREC no 1 B .2 H .1 MNO 1 $Cross section
+PROG SOFIMSHA urs:2
HEAD Definition of geometry, supports, and beam element
$ Definition of the system type
SYST 2D GDIV 10000 $ 2D system for plane structures
$ Geometric definition of the model nodes
NODE NO 1 X 0.0 Y 0.0 FIX PZ $ Pinned support at the left end
NODE NO 2 X 3.0 Y 0.0 FIX PZ $ Pinned support at the right end
NODE NO 3 X 1.5 Y 0.0 $ Node in the middle of the beam
$ Definition of the beam element between the nodes
trus NO 1 NA 1 NE 2
+PROG SOFILOAD urs:3
HEAD Definition of the model loads
$ Define the permanent action for self-weight
ACT G
LC 1 DLZ 1.0 $ Load case 1 includes the self-weight of the structure
$ Define the action for the point load
ACT Q
LC 2
NODE NO 3 TYPE PZ P 5.0 $ Point load of 5 kN at Node 3 in the Z direction
PROG ASE urs:4
HEAD Analysis of individual load cases
LC ALLE
