I need to access the database to retrieve the forces in the springs using the @key command.
Does anyone know how to do this?
Is there a guide that explains how to access any parameters and values stored in the database (nodes, springs, beams, etc.)?
Take a look at the basic example in your installation folder (and the other files in the folder too):
C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\interfaces\examples\cadinp\cdb-access-examples_1.dat
You find the different access keys in the cdbase help manual:
So the result from a spring element you would find under:
Sofistik data/explicit elements/(17?) spring, dampers:
