Hello Sofistik community,
I need some help understanding punching shear results.
As seen below, the table (i.e. from reports) has AssSum
with ****
and -
. It is defined in the description (second image) that ****
means ‘proof of punching shear not provided’ . As a result, we (my structural engineering colleagues) have redesigned only the rows with ****
in AssSum
Now as part of my automation job, I need to filter the available Punching shear directly from the database(CDB). Despite this, the CDB actually does not have a column for AssSum
but just 4 additional columns with some names in it (ASV1, ASV2, ASV3, ASV4)
So, my questions are:
Is the
sum of (ASV1,ASV2,ASV3,ASV4) = AssSum
If yes, Would you please tell me how I can categorize them after summation into
and-
(What is the differentiation factor for****
and-
If not, How can I obtain
AssSum
from CDB? -
Alternatively, if all the above are not possible, how can anyone identify the critical nodes manually (assuming there is no filtering (
) available in the report) ?
Anykind of information helps me a lot!! Thanks in advance for your response!!
