I’m modelling two walls which share an edge. That edge should not transfer shear between the walls.
I suspect I need the “SARB FIX” syntax, but I can’t seem to get it to work?
Please see the following code sample:
+prog Sofimshc urs:21.1
SYST 3D GDIV 100000 GDIR NEGZ
CTRL MESH 1
SPT 1 X 0 Y 0 Z 0
SPT 2 X 1000 Y 0 Z 0
SPT 3 X 1000 Y 0 Z 1000
SPT 4 X 0 Y 0 Z 1000
SPT 5 X 2000 Y 0 Z 0
SPT 6 X 2000 Y 0 Z 1000
SAR 1 MNO 11 GRP 11 T 100
SARB TYPE OUT NA 1 NE 2
SARB TYPE OUT NA 2 NE 3 ! shared edge
SARB TYPE OUT NA 3 NE 4
SARB TYPE OUT NA 4 NE 1
SAR 2 MNO 11 GRP 11 T 100
SARB TYPE OUT NA 2 NE 5
SARB TYPE OUT NA 5 NE 6
SARB TYPE OUT NA 6 NE 3
SARB TYPE OUT NA 3 NE 2 ! shared edge
SLN 1 NPA 1 NPE 5 FIX F
+prog sofiload urs:50.2
ACT 'G' GAMU 1
LC 1 TYPE 'G' TITL 'test'
LINE AUTO PROJ N TYPE PZZ P1 -10 X1 1000 Y1 0 Z1 1000 $$
P2 -10 X2 2000 Y2 0 Z2 1000
+PROG ASE urs:51
LC ALL
Thank you
