I an using “Talpa” to model construction stages for a longitudinal analysis of a concrete tunnel. The tunnel is modelled as beam elements and the soil is modeled as quad elements. Sofistik gives the following error message: “Fehler Nr. -101 in Programm BEAM_INIT_POST:100/0 not ok”. Do anyone know what the error message means?
I a assume you are working with WinTUBE? Are you using the current SOFiSTiK service packs for the version 2020? I heard about this error message in WinTUBE and TEDDY 2018.
If a program update does not solve the problem, you could try to switch to the standard beam elements with the following command.
CTRL OPT BEAM VAL STD (STEU OPT BEAM WERT STD)
