Hi!
I created a “Cuts” in the Sofiplus from I took some results of internal forces. Later, I wanted to export result with corresponding forces. For example, I need table with result like that in Excel:
As I understand I can only export results of “Cuts” from Wingraf. Is it possible to create list of result in the same way as on picture above?? I mean, is it possible to create columns with forces side by side??
It would be quite easier and quickly to export my data to Excel in that way.
I only listed result in Wing and then created Reports on this way:
