I am new to the topic of TEDDY and its interface. I am trying to get more examples on how to build a simple structure and run analysis to it using C# and the interface of TEDDY. If someone has any good example or more information that I could use to learn would be very helpful!
Open Teddy and go to:
→ File → Examples
Here you can find small examples of modelling/calculating using teddy.
Teddy is basically a text editor with syntax highlighting for sofistik input language (cadinp)
Regarding interface (C#):
I recommend you keep it clean:
Input → Use C#/python/etc to generate text files with cadinp syntax
Output → Use the report browser/wingraf/dat_export program to generate text/excel files (easier/quicker than cdb access)
If you want to use the interface, you basically have to look at the documentation:
