ELLA calc
Hi!
I am designing portal, frame bridge in 2D. Model is created by beam element with 1m width. I assigned axis to my top slab and I want to calc vehicles in ELLA. I got this error:
”The complexity of a geometric axis for plane frames exceeds the admissible limits for users and programmers in many cases.”
It is quite easy model and I am wondering what it refers to…
Greetings, Andrzej
Hi Andrzej,
please see ELLA manual chapter 2.7 - Limits-
*The application of ELLA for plane frames or shear walls provides so many ambiguities, that we do not support this feature currently.
That’s exactly what is written in the error message, you cannot use ELLA for a 2D frame model.
You may use a load stepping approach instead, or make a full 3D system
