recently I have ran some of my old code on sofistik 2023 and I have found weird thing.
When you modify FACS of element by ELEM command in ASE dead load also modifies which did not before.
Is this changed on purpose or there is some kind of bug?
Seems like a bug, because not only dead load is modifies but any load, not only primary load but even external load applied together with elem command in one ase run.
+prog aqua
head
mate 1 e 10000 mue 0.2
+prog sofimsha
head
syst spac gdiv 1000
node 1,2,3,4 0,1,1,0 0,0,1,1 0
node mesh 1 2 div 10 fix F
quad mesh 1 2 3 4 m 10 n 10 t 200[mm] mno 1
+prog sofiload
head
lc 1
quad grp type pzz p 10
+prog ase
head
lc 1
+prog ase
head
elem quad no 24 facs 0.001
lc 2 ; lcc 1
