I have noticed that some folks in my company skip eccectricity load effect of LM1 acting with load group GR_2, GR_a, GR_b (please correct me if needed) because they don’t know how to implement the point load into the model, so it would follow the LM1 trolleys (300kN+200kN+100kN), so on 700 m radius, i get sum 35 kN point Load. How to include this in model? Should I divide it to equaly between trolleys, then how to make it follow trolleys? Another way I guess is to create just a running point load. BUT my bridge is in curve and it is problematic to place that running load. Should I use many points? Is it the only way to assign that load? Also how to define teddies. Maybe there is any example regarding that issue. Thank you! Greetings from Lithuania.
still a question
Hi Needlesky,
I don’t understand exactly the problem, but you find an example with load stepping and ELLA here:
https://docs.sofistik.com/2023/en/tutorials/bridge-design/slab-bridge/slab-bridge.html
If you change the alignment of the axis in SOFiPLUS and the bridge is therefore curved, it should also work.
I hope this helps.
Jost
