Hello everyone,
I’m still relatively new to Sofistik. I need to model a multi-story building and I’m stuck at one point. I have defined the first surface element using a loop command (see image). How can I duplicate this defined surface in such a way that I only need to change one parameter for the maximum number of levels at the end?
Hi Artur,
using parametric teddy code is not the easiest way to start with the Software. If you use Sofiplus you can simply copy the areas to the next level.
In Teddy, maybe command TRAN would be the best option (see example file attached). Otherwise you have to define another LOOP for the z coordinate of the nodes.
Best Regards,
Nora
multi_storey.dat (742 Bytes)
