Hi
I have the following files:
subfile1.dat:
+prog template $ subfile 1
let#var1 1
subfile2.dat:
let#var1 1
I wish to run these two files from a main.dat file.
I would imagine the main.dat file should look like this:
+apply subfile1.dat
+apply subfile2.dat
But this doesn’t work with the error message There are no active modules.
As such, I need a dummy module to run prior to any +apply commands, thereby the file looks like this:
+prog template $ dummy
+apply subfile1.dat
+apply subfile2.dat
This would be okay, but every now and then I only need to run subfile2, which I would then run by clicking the +apply subfile2.dat in the Module Tree. But again, I get the same error message There are no active modules.
That means that in order to run the files individually, I need to set up the main file like this, and run it by chapters instead:
!#!chapter subfile1
+apply subfile1.dat
!#!chapter subfile2
+apply subfile2.dat
Do I really need this dummy run in order to run an +apply command? Isn’t there some clever workaround?
