Hi everyone,
I’m currently modeling a single-span composite bridge using thin-walled cross-sections for the steel girder and a slab. I’ve based my setup on the example decreator_08_composite with variable sections.
However, I’ve run into a problem with DECREATOR module:
Here’s the issue:
- When I choose DSEL BEAM, the internal forces from the self-weight check seem incorrect, but I can map the traffic loads from the ELLA module successfully.
- But for DSEL SEC, I get correct results for the self-weight, but I’m unable to map the traffic loads from ELLA.
I clearly have a problem with the point at which the internal forces are being read when using the BEAM option, but I can’t figure out where I’m going wrong.
composite_bridge_sofimshc.dat (43.2 KB)
