Decisive case in ELLA
I am loading a bridge with 6 lanes with ELLA. In the simple code below, each “CASE” is a possible loading configuration for the Tandem System and the envelope is succesfully stored under LCs 900100.
SAVE LCB 900100 TYPE GR_T TITL 'TANDEM'
LOOP#Case_i #Num_Combinations
    CASE 1+#Case_i GRP GR0
        POSL 'AXE.1' TRAI #LC_Lane_1(#Case_i)
        POSL 'AXE.2' TRAI #LC_Lane_2(#Case_i)
        POSL 'AXE.3' TRAI #LC_Lane_3(#Case_i)
        POSL 'AXE.4' TRAI #LC_Lane_4(#Case_i)
        POSL 'AXE.5' TRAI #LC_Lane_4(#Case_i)
        POSL 'AXE.6' TRAI #LC_Lane_4(#Case_i)
ENDLOOP
I have watched the following youtube tutorial where it is clearly explained how to find the loads that generate, for example, the maximum bending moment My for a given element, axis and case.
Load Copy from ELLA #SOFiSTiK #SOFiSTiKTutorial #Tutorial #ELLA #Loadcopy
However, how can I know the decisive case that generates the maximum bending moment My for a given element and axis? Basically, I want to know which loads generate the maximum bending moment in a specific element, and I need the decisive case to generate that.
Hi Andrew,
you must generate several load cases from each ELLA-case, calculate them with ASE and check the results to realize which is the relevant one.
Jost
Can anyone explain how to calculate and check reaction from ELLA to wingraph and how to use convert or use ELLA loadcases in load combination as ASE or Sofiload
Dear Wasee-Khan,
first of all I recommend to open an own topic.
Regards,
Jost
