I’m trying to model an ETFE cushion with steel edges for a home work at my university
I created two lyers of ETFE and wanted to support them with the steel edges and prestress it using a volume between the two layers, but when I’m trying to support the upper leyer with the steel edges it woldn’t work
I want to support the edges of the upper ETFE with the edges of bottom one
this my code
$Folienkissen; Lagen ETFE
#define laenge = 1 $m; x-Richtung der Folie → ED
#define breite = 1 $m; y-Richtung der Folie → TD
#define abstand = 0.001 $m; abstand zwischen die beide membran ebenen
#define dicke_o = 0.25 $mm;
#define dicke_u = 0.25 $mm;
#define E = 1000 $MPa;
#define nue = 0.45 $-
#define druck = 0.3 $kN/m 300 pa
#define druck_s = 0.6 $kN/m 600 pa
#define vorsp_o_ED = 1.56 $kN/m
#define vorsp_o_TD = 0.78 $kN/m
#define vorsp_u_ED = 1.56 $kN/m
#define vorsp_u_TD = 0.78 $kN/m
#define schnee = 0.52 $kN/m
#define windsog = -0.78 $kN/m
#define winddruck = 0.5 $kN/m
#define m = 10 $unterteilung in x_Richtung
#define n = 10 $unterteilung in y_Richtung
+prog aqua urs:1
kopf Kissenstruktur - ETFE
echo VOLL VOLL
norm ‘DIN’ ‘EN1993-2005’
mate nr 1 E $(E) mue $(nue) E90 $(E) GAM 0 BEZ ‘ETFE-FOLIE’
nmat nr 1 art MEMB
Norm DC EN 1993-2005 cat A
stah 2 s 355
stah 3 s 355
qnr 3 mnr 2 bez ‘Randträger’ ; prof 1 warm 193.7 16 $Rundstahl nach EN 10060
qnr 4 mnr 3 bez ‘Stützen’ ; prof 2 warm 193.7 10 $Rundstahl nach EN 10060
ende
+prog sofimsha urs:2
kopf Kissenstruktur - ETFE - Volu Luft Volume Technik
syst init $ system löchen aber die Systeminfo behalten
syst 3D GDIV 10000
knot 1 2.3 -5.3 0
knot 2 2.9 -6.5 0
knot 3 4.3 -6.6 0
knot 4 5.2 -5.5 0
knot 5 3.2 -4.2 0
knot 6 4.7 -4.5 0
knot 11 2.3 -5.3 0.001
knot 12 2.9 -6.5 0.001
knot 13 4.3 -6.6 0.001
knot 14 5.2 -5.5 0.001
knot 15 3.2 -4.2 0.001
knot 16 4.7 -4.5 0.001
knot 1 fix pp
knot 4 fix pp
knot 5 fix pp
$knot imsh 11 12 fix pp
kine 11 pp 1
kine 12 pp 2
kine 13 pp 3
kine 14 pp 4
kine 15 pp 5
kine 16 pp 6
grup 3
stab fit ka 1 ke 2 qnr 3 teil $(n)
stab fit ka 2 ke 3 qnr 3 teil $(n)
stab fit ka 3 ke 4 qnr 3 teil $(n)
stab fit ka 4 ke 6 qnr 3 teil $(n)
stab fit ka 6 ke 5 qnr 3 teil $(n)
stab fit ka 5 ke 1 qnr 3 teil $(n)
grup 1
$quad fit k1 1 k2 3 k3 4 k4 5 m12 2 m34 6 mnr 1 t 1[mm] kr posx m $(m) n $(n) $ area number 1o
quad fit k1 1 k2 2 k3 3 k4 5 mnr 1 t 1[mm] kr posx m $(m) n $(n)
quad fit k1 3 k2 4 k3 6 k4 5 mnr 1 t 1[mm] kr posx m $(m) n $(n)
grup 2
$quad fit k1 11 k2 13 k3 14 k4 15 m12 12 m34 16 mnr 1 t 1[mm] kr posx m $(m) n $(n) $ area number 1u
quad fit k1 15 k2 13 k3 12 k4 11 mnr 1 t 1[mm] kr posx m $(m) n $(n)
quad fit k1 15 k2 16 k3 14 k4 13 mnr 1 t 1[mm] kr posx m $(m) n $(n)
ende
-prog ase urs:3
kopf Formfindung - Volu Luft Volume technik
echo voll voll
syst prob th3 nmat nein iter 400 tol 0.001
grup -
grup 1 faks 1e-10 vorx $(vorsp_o_ED) vory $(vorsp_o_TD) $ bringe Voespannung ein für obere Foile
grup 2 faks 1e-10 vorx $(vorsp_u_ED) vory $(vorsp_u_TD) $ bringe Voespannung ein für untere Foile
volu 1 grp 1,2 V0 $(laenge)$(breite)$(abstand) P0 $(druck) $posi negz
lf 1 fakg 0 bez ‘Formfindung’
ende
