I get an error in the CSM, which I am trying to switch off with “CTRL WARN 43” as advised by Sofistik:
+PROG CSM urs:64
HEAD CONSTRUCTION SEQUENCE
CTRL WARN 43 $ Load or mass on node 11526 loadcase 41061 not defined or node not activated
However, despite including “CTRL WARN 43” in the teddy file, the error keeps showing:
+++++ error no. 43 in program LOAD
Load or mass on node 10000 loadcase 41061 not defined or node not activated.
This error message can be switched off with CTRL WARN 43.
