Hi All,
I’ve come across a little problem trying to assign bedding properties to my structural points (generated through a loop) using SPTS command.
Here is the code:
IF #PP==2
LET#NX (5050+100*#NRP1)
LET#DX (#OF1-#OPP1)
SPT NO X Y Z
5150 #DX 0 #H1
(5250 #NX 100) ((#DX-#RP1) -#RP1) 0 #H1
SPTS (5150 #NX 100) CP 10000 CQ 5000
ENDIF
I’ve tried to find a way around but right now I cannot come up with anything.
The SPTS only put spring on the last record of generated SPT.
In this case #NRP1=3 so I generated 3 points: 5150, 5250, 5350 but as I mentioned before - the spts only works for the last generated point - 5350.
Is it even possible to do it with SPTS command?
