Dear SOFiSTiK forum members!
Is it possible to create multiple instances of ASE programs with loops in Teddy?
For verification purposes I am trying to calculate multiple setups of a structure in a single SOFiSTiK file. Part of the problem requires me to calculate buckling eigenvalues for each setup. What I have tried is:
+PROG ASE
HEAD Buckling eigenvalues
LOOP#i d
SYST PLC 100
GRP 1+#i
EIGE NEIG 2 ETYP BUCK LMIN AUTO LC (#i+1)*100+1
ENDLOOP
But this is not possible because only one buckling analysis is allowed in a single ASE run. So I would need to create separate ASE programs for each buckling analysis. I want to do it automatically because I am trying to do some verifications for a lot of different setups. So I also tried the following
LOOP#i d
PROG ASE
SYST PLC 10
GRP 1+#i
ENDLOOP
But that does not work either. Is it possible to create multiple ASE programs with loops or do I have to use API for that?
Martin
