Create Constrain for an already existing node
I would like to add a constrain to a previously defined SPT.
For example, I create the node “1” and create a link with node “2”:
        SPT NO 1 X 0 Y 0 Z 0
        SPTP TYPE KF REF 2
Later in the script I would like to connect node “1” to node “3”; however, when I call node “1” to create this new link it eliminates the previous ones. Is ther a way to solve this? Obviously, there is an option to define both links when creating node “1”, but that is not the solution that I am after.
        SPT NO -1
        SPTP TYPE KF REF 3
Does anybody have a reply to this? :slight_smile:
SPT -2; sptp type kf ref 1
SPT -3; sptp type kf ref 1
Hi Mico,
Thanks for your reply, but I think your code does not solve the issue, does it?
With this command “SPT -2; sptp type kf ref 1”, the previously defined constrains at node 2 get deleted.
What I want is to define a new constrain in node 2 without deleting previously defined constrains at this node. The thing is that I would like to create the constrains in two separate blocks: first I define the temporary supports bearings / constrains and then the permanent ones. Since, in some cases, the node for permanent and temporary bearings is the same, I would like to add a constrain to a previously defined node without deleting the already existing ones.
You should not (or even cannot) define multiple constrains of the same degrees of freedom for one node.
If you want to try do it in sofimsha after sofimshc:
prog sofimsha
syst rest
node 1 fix kf 3
