Copy geometry from existing CDB
I have been using the module DBMERGE to copy LCs results from a different CDB and it works fine.
I am wondering whether it is also possible to copy the geometry (sofimsha / sofimshc + aqua) from an existing database?
Do you know the command »export to .dat«?
With the record IMPO of sofimshA you can copy the geometry from another CDB.
Please don’t use IMPO this is a very special command as written in the manual and not designed for all purposes.
I would use export to dat from the TEDDY / SSD menu “Database Tools”
