Contact modeling between two gapping rings
I am currently working on modeling two overlapping, dry-jointed reinforced concrete rings that are prone to gapping under bending stresses. I would like to accurately capture the separation behavior between the rings.
Aside from using contact springs, what other modeling approaches are available to realistically represent the interface behavior between the rings?
Thank you in advance.
Hello @BinOmran
I think the easiest way to define contact between two area elements is described in the following two topics:
To use this method, you have to make sure that the coupled elements have similar mesh
With best regards,
Martin
