How can i model two overlapping plates, so they transfer loads, and work as one unit?
So far i modelled plate 1 and plate 2, but they cannot share any structural points, because the structural points are defined with a Z value. That will ofcourse not produced what was intended if i connect with them via structural points.
But, when running the model, i see that plate 1 will have a large displacement at the corner - it does not recognize pile 2, or in other words - it does not care that plate 2 is there.
Each plate is modelled as its own structural area.
Any suggestions on how i can connect them, without doing it via structural points?
F is a fixed support to the “ground”
KF is kinematically fixed to a point.
Basically the former is a support and the later a kinematic coupling (sofimshc manual)
In my experience you can write both KF or F and it works.
The - is in order to change an existing point:
You define all the geometry points (e.g. in a loop)
