Hallo Everyone,
I am going through the Teddy Example files and i came through this Command BGEO(aqua31_bridge.dat), which i have difficulty in understanding the command. I couldnt find any explanation in the Handbuch either. Can anyone help me with this command? Thank you in advance.
Dixon
In the SOFILOAD! -Manual you can find a desription (BGEO isn’t a command):
IMO: BGEO is a keyword for (instance?) the MSHC-AQUA-interaction (if you at first define a parametric cross section-description, then you can in MSHC store in this way specific edges, coordinates or what ever on a specific station.
A next AQUA-INTE-RESTART read the specific Station-Values and compute (and assign) a modified section.
Thank you so much
