Can someone please point me to how I can apply a radially changing load to a cylinder ?
Basically I’m trying to manually apply wind loads on a cylinder (as per Indian Standards) and look at the transverse bending moments. The loading reference figure is shown below
(I’m aware of the WIND loading in Sofistik but it does not cover Indian Standards so I’d like to do this manually and would greatly appreciate any help / pointers !)
My first idea would be to divide the surface into smaller strips that can then be loaded with a surface load. You can then activate a variable load for this load. This workflow discretizes the variable load. The thinner the strips, the better the load approximates the specified load.
