Hi there
I have a 3D model of a concrete structure using structural areas. The base slab of this structure is modelled with bedding quads. I’m analyzing different construction stages in CSM and i need the bedding quads to change material number (change in bedding stiffness) in different CS. Is there an input for this in CSM or do i have to change this in the generated ASE-input?
As far as I know, this is not possible in CSM. You can only activate or deactivate the QUAD-bedding (GRP … BEDD). But you can change the factor of the quad-bedding within ASE. This means, you have to manually adjust the created $(project)_csm.dat file.
Please have a look at this short example
!#!Kapitel CSM construction stages
$ ----------------------------------- Construction Stage 20 ----------------
+PROG ASE urs:csmase20
HEAD Construction stage CS 20 Selfweight
sto#cs_csm 20 $ use of variable #cs_csm in CTRL ASE TEXT see manual -> CTRL CANT
#include ASE_CTRL
SYST PLC -
GRP 1 CS 20 T1 28.0 FACD 1 HING ACTI FACB - $ define factor for bedding
GRP 20 CS 20 T1 28.0 FACD 1 HING ACTI FACB -
LC 4020 TYPE - TITL "Selfweight " $ dead load via GRP FACD
