Has anyone an idea of what is missing in this syntax?
With the “@key beam 0 #stab” command, it reads from CDBase just fine. However, when I use the “@key beam_sct” command next, the variable (#qnr_i) yields either in the bar’s number or zero, not the bar’s cross-section number. All of this is performed inside a couple of loops.
Thanks for your answer! Indeed, when I use only the snippets with our file, it works perfectly fine.
I further implemented this model for something that is more close to what I am experiencing now. Much more groups, bars and cross-sections, that follow some logic behind.
Please kindly see the file attached.
Now, without changing the +template part from your file, the variable @(nq) leads to the same bar number that it was supposed to read, not the cross-section’s number. This problem I also experienced trying to implement it in my model before.
In the following +template parts, I expanded the idea for reading the CDBase to something that I was aiming for. As you can see with the loops, it works just fine for the “@key beam” and “@key beam_foc”, but not for “@key beam_sct” for some reason… Even without the loops, it cannot read the cross-section number as intended.
It seems that with a small change in the model, the command cannot find the information anymore.
Thanks again and I look forward to see our comment on that.
