Hello everyone,
I have an issue with the SOFiMSHC module.
I use the command SYST TYPE REST when creating a new module, but when I run it several times, the program says that the structural elements are already defined.
I found a solution by deleting the database, but it’s annoying to have to delete it before each model run.
I tried using the following command:
SYST TYPE INIT — it works, but the problem is that it erases the previous modelling.
Do you have any idea?
Because in another model, the command SYST TYPE REST works. Maybe it’s just a bug?
thank you.
Esteban
