Available results from Wingraf do not exist in Database
i’m trying to get some values, for instance Max SLS design steel stresses from CDBase since I need table with values and I can’t obtain it through result viewer.
But when I check my DataBase info I do not see the 27’ record for quad design results.
Why is that?
Sz.
I managed to find let’s say a small workaround but the best I can do is table with list values in report browser:
PROG WING urs:1
$ GRAPHIC document (version ####-##.## build #######) from Service Pack 2023 12 Build 1017 14.03.25 , 14:53:41
HEAD $ Top Maximum SLS design steel stress DC: 2
UNIT 0 SET IN $ default unit set
CTRL OPT GSTR VAL DEFA
CTRL OPT REPR VAL YES
DB NUMB 1 TITL “mk1_kn.cdb”
CTRL OPT AXIS VAL DEFA
$ graphics 1 | picture 1 | layer 1 : Top Maximum SLS design steel stress DC: 2
PAGE LANO 1
SIZE TYPE URS SC 0 MARG NO
SIZ2
AND POSI 1 POSL 0 POSR 100 POSD 0 POSU 100
SCH2 DIRE DEFA
LC NO 1 DESI 2
BOX
GRP NUMB NODE OPTI OFFL
GRP NUMB ENOD OPTI OFFL
GRP NUMB EDGE OPTI OFFL
GRP LC NO
GRP NUMB 0 YES GLN
loop#grp 3 ; GRP NUMB 10+#grp YES QUAD,GAR ; endloop
GRP NUMB 13 OFF
loop#grp 4 ; GRP NUMB 21+#grp OFF ; endloop
GRP NUMB 30 OFF SPRI
GRP NUMB 30 YES GLN
loop#grp 6 ; GRP NUMB 31+#grp OFF ; endloop
loop#grp 3 ; GRP NUMB 50+#grp OFF ; endloop
loop#grp 4 ; GRP NUMB 71+#grp OFF ; endloop
loop#grp 4 ; GRP NUMB 81+#grp OFF ; endloop
loop#grp 4 ; GRP NUMB 171+#grp OFF ; endloop
loop#grp 4 ; GRP NUMB 181+#grp OFF ; endloop
GRP NUMB 510 OFF
GRP NUMB 520 OFF
GRP NUMB 710 OFF
GRP NUMB 720 OFF
GRP NUMB 730 OFF
GRP NUMB 740 OFF
VIEW TYPE DIRE X 0.864813 Y -0.422351 Z 0.271511 AXIS POSZ ROTA 0
DEFO TYPE NO EXPO 0 SMOV NO
SELE NUMB 0
QUAD TYPE SSUM UNIT DEFA SCHH YES STYP ELEM FILL NO REPR DLST AVER NO
$ Definitions of interactive work
iNTE SET 0 PAR1 1 PAR2 1 PAR3 1 PAR4 0 PAR5 0
Do you know is there a way to export automatically these values to .xls file?
Can you share your code for the BEMESS module? I think you need to save the calculation results in a specific LCST.
+PROG BEMESS urs:12
HEAD OGRANICZENIE NAPREZEN 0.6 0.8
CTRL WARN 608
PAGE UNII 0
CTRL LCRI 1
CTRL LCR 2
CTRL PFAI 2
ECHO REIN,RTAB,SIGS YES
CTRL SLS
LC RARE
NSTR CHKC 0.6 CHKS 0.8
GRP 10,11,12,21,22,51,52,71,72,73,74,81,82,83,84
