I want to perform a non linear stress analysis in two separate modules, first the piers and then the deck. Therefore, I use two separate AQB runs.
Although the AQB code works just fine (see below example for the piers), when I run the second AQB for the deck, it deletes the results of the previous AQB run (the Load Cases that I am using in both AQBs are the same, corresponding to SLS Rare).
Is there a command so AQB does not to delete the previous results?
-PROG AQB urs:53
HEAD PIERS - NON LINEAR STRESS - SLS RARECTRL REIN FIX
BEAM GRP #GRP_Piers
LC (#Base_SLS_Rare+1 #Base_SLS_Rare+#Num_LCs_Env_Beam 1)COMB GMAX LCST #Base_SLS_Rare+96 TITL ‘Piers_SLS_Rare_Max’
COMB GMIN LCST #Base_SLS_Rare+97 TITL ‘Piers_SLS_Rare_Min’NSTR SERV KSV EL KSB EL CRAC NO CHKR 0.8*#Fyk_Reinforcem[MPa] CHKC 0.60*#Fck_Conc_Piers[MPa]
ECHO FULL FULL
