Hello, I am trying to add moving load on my bridge but constantly there is an error. I cannot understand how to proceed further. Please help!
What’s the error message?
hi, yeah i am getting this error message
ELLA needs a pre-existing stiffness matrix.
Solve your system in ASE for another loadcase (e.g. self-weight) before running ELLA.
So, your suggestion is that I do a dead load evaluation of the bridge ain ase and then write the command for ella?
Yes
Just insert:
+Prog Ase
Lc No 1 Facd 1.0
End
before ELLA
First, you should take a look at the report browser to immediately see which command is in error.
After that, you should look into the ELLA manual and check the command syntax.
If you are a new user, I suggest using the SSD to build your project.
If you want to use the TEDDY, see the example files for help.
