No, it is not possible to directly define a load case that would contain internal forces (such as axial force, bending moments, shear forces) in the SOFiLOAD programme.
Here is why and how the roles of SOFiLOAD and AQB differ in this respect:
- Role of SOFiLOAD: SOFiLOAD is designed to generate external loads applied to the structure. These loads can be:
◦Nodal loads (NODE).
◦Loads on elements (BEAM, BEPL for beams, QUAD for surface elements, BRIC for volume elements).
◦‘Meshless’ loads (independent of the mesh) such as point loads (POIN), linear loads (LINE), surface loads (AREA) or volume loads (VOLU).
◦Dynamic loads, load trains (trains), or wind loads. These external loads are then used in structural analysis programmes (such as ASE or STAR2) to calculate the internal forces in the structural elements.
2.Definition of internal forces in AQB: The ability to directly define internal forces applied to a section, such as that of a pile, is a specific feature of the AQB programme. In AQB, you use the LC record to select a load case, then immediately after, the S record to define the internal forces and moments (N, VY, VZ, MT, MY, MZ, MB).
◦These internal forces and moments are then recorded under the load case specified by LC.
◦This is particularly useful for the analysis and design of individual sections, even if these forces do not come from a complete static analysis of the existing system.
◦It is important to note that this action deletes any pre-existing load results stored under the same load case number in the database.
In summary, SOFiLOAD is used to apply external loads that will produce internal forces after a structural analysis, while AQB allows you to work directly with internal forces on sections for their design and verification. These two programmes have complementary but distinct roles in defining what constitutes a ‘load case’ at their level.
Abderrahman OMRI
