I am woring on elastic bending of plates, and I have troubles getting correct results using the ACTB module. In the attached project I have a simple rod and a plate (which is an extrusion of the rod-curve) that should give the same end results. However, the final shape of the plate differs quite a bit from the shape of the rod. Can someone please have a look and maybe tell me what I’m doing wrong.
Thanks,
David
BAP_benchmark.sofistik (35.3 KB)
BAP_benchmark_msh.dat (224.5 KB)
BAP_benchmark_aqua.dat (3 Bytes)
