I would like to know why the Head LIne of Wingraf disappears when I export the PLB Report to DOCX. I mean the second line of “Head line of drawing” in Wingraf’s Drawing Setup, not the one from DB.
On the contrary, when I export to PDF the Head Line is OK.
My SSD and Wingraf version is 2020-10.
Can someone help, please?
Hello Vassilis
The second head line of the Graphics drawing is not exported to docx. This is because the export only exports the first HEAD command (prog wing). So please do not use the second head line if you want to export the .plb to docx.
The PDF-export does export the second HEAD command, because it uses an other (older) algorithm.
Thank you Frederik for your answer.
I hope that the PDF export will continue in 2022 SSD edition to include the 2nd headline, as it is very helpful to me to describe the wingraf drawing.
Best Regards
