When activating warping, the corresponding degree of freedom (which should be the first derivative of the twist angle) is missing from the output results!
How would it be possible to get those values!
Thanks in advance.
Thanks in advance.
Have you tried to activate advanced output in modul ase with command echo disp full? Or echo full extr.
There is also example which could help you.
At Teddy - Help - Manuals - Verification Benchmark Mechanical - BE6 Warping
Nils Albrecht
SOFiSTiK Support Team
