I’m working on a university homework and I want to run the LM71 load on my bridge.
The result is this warning message:
++++ warning no. 2073 in program ELSMZ ; input line: 27
Case 1 lane AXIS.1 Load train does not match the lane width parameters 1.435 1.435 IE= 2
For INT 3 (or 5, 7, 9) a loadtrain or width and wheel spacing has to be specified in record LSEL.
These values should match the specifications of the load train.
=> Parameter WIDT in record TRAI and Parameter B in record TRBL/TRPL
+++++ warning no. 89 in program ELSM
Case 1 lane AXIS.1 Due to the for transverse influence evaluations
different excentricities can not be evaluated precisely.
The value parameter of WIDT in command TRAI in module SOFILOAD must match with the parameter B in command LSEL of module ELLA. Otherwise an error message will be triggered.
Similarly the value of B in command TRAI in module SOFILOAD must match with the parameter BWH in command LSEL of module ELLA. Otherwise a warning message will be issued.
As the graphical user interface of ELLA is not capable of handling Railroad Bridges with its predefined load trains, you have to add the expression B 1.435 BWH 1.435 manually to the command LSEL in ELLA.
So convert the Traffic Loader task into a TEDDY task and revise the input.
If you need further help, please have a look at our TEDDY examples.
TEDDY > File > Examples > ella > english > …
I added the B 1.435 BWH 1.435 expression manually to the LSEL and got the following warning:
+++++ warning no. 12155 ; input line: 16
The item B @LSEL is an obsolete input option. Please note, that future
SOFiSTiK major releases will no longer support this option.
Please check the manual for alternative input possibilities.
Please be aware, that the obsoleted item may have been shifted to a different position in the record
The item BWH @LSEL is an obsolete input option. Please note, that future
I use the 23. version of Sofistik, may it cause the problem?
It’s strange as well for me, that the coded “b” and “bwh” are not light blue. It looks like these parts are not active.
