Is there any option to set variable to change two values on one time?
What I mean, is it possible to combine two variables as one (picture below) to transit point A to point A’?
Dear Mateusz,
If I understand you correctly, you want to fill a variable with 2 different values.
In my opinion this is not possible in the sofiplus environment Therefore you have to create one variable for the horizontal part and one for the vertical part.
with kind regards
SOFiSTiK Support Team
Nils Albrecht
Yes you understood me well. Thanks for replay and as I think its not possible but i wanted to be sure
Thanks for help
Is it possible to set two different parametric points (with different variables) to one node?
I am not sure what you mean, could you try to make a sketch or a screenshot?
Thanks
