Dear all,
I am wondering if it is possible to control the thickness of an area element with a variable defined along an axis, as it is possible with beams cross-sections.
Thank you !
Kind regards,
Andrei
Dear all,
Thank you !
Kind regards,
Andrei
Hello Andrei,
I can only confirm your assumption. As far as I know, you can use the variables along an axis (gaxv) only for structural lines with cross section.
You could set the thickness of a structural surface to zero and define the edge thickness, this will interpolate the intermediate values.
Maybe this bridge tutorial will help too:
https://www.sofistik.de/documentation/2020/en/tutorials/bridge-design/slab-bridge/slab-bridge.html
Nils
SOFiSTiK Support Team
