Hi everyone!
my question is when I export unidirectional floors from revit to sofistik, I have floors on two directions, is there a solution?
If the floor plate should only carry the load on one axis, you can reduce the E module in the corresponding direction.
In Module ASE use command GRP2 QEMX or QEMY 0.001.
You can also use the function “Edge release” to free to the slab edges in the direction which you do not want to consider.
This allows you to have the desired effect without having to go in SSD for a text input.
Regards,
Xavier
