Do you know how can i solve this error in the traffic loader. Saying that “illegal load case number 1202 for results, as used by load train definition” ??
Thank you
Thank you
As the error message tells you, you can’t use the same load case number for the load train and the result load cases from ELLA.
So I would check the assigned load case numbers in the Traffic Loader Task. Make sure to use different numbers and keep in mind, that you get multiple result load cases (as defined in the calculation tab of the Traffic Loader).
